Narrow Whitewalls - How to
Post by Paul on Thu 11 Dec 2008, 3:50 pm
Sick of staring at all those blackwall tyres in your parts bin that are almost good for nothing?, Here's how I make mine useable.......
1/ Next time your down the local newsagent picking up your latest cool Car Magazine or Woman's Weekly( Suspect ).................head for the pen section and pick up some gel pens, about $2.50 each.
Here's the one's I use,
They come in lots of neat colours too,
You will also need a circle template ( Newsagent should have them too or try officeworks) I already had one handy for painting Wide Whitewalls with Tamiya Primer ( Want a tutorial on that?? ).
Grab your chosen tyre an some blue tac! I'm using Amt's generic Firestone skinny, I'm sure these will never become rare lol! .
Next install either the rims you will be using or an old one that fits, this makes it a lot easier to center in the circle template.
Blue tac it in,
Then flip it over and get in centered, which is easy with the blue tac and not so easy if you use tape!
Grab your newly acquired gel pen in your chosen colour an start,
You may need to go over it a few times and the more you go over it the wider the stripe, work carefully.
Gently pull your tyre away from the rear and don't touch the ink as it takes a while to dry and even then don't touch it, if your not happy with the result grab a cloth and wipe it off, even for these pix I had to do it twice!
Ok that's one tyre down you now have 3 more to do! make sure in between every tyre you clean the circle template with a cloth to remove the wet ink still on it.
Once you've done all 4 install them to your chosen project!
here's some examples of other colours done the exact same way!
Gold
Blue
Give it a shot and be sure to post up you results!!
Re: Narrow Whitewalls - How to
Post by Robert81 on Thu 11 Dec 2008, 3:58 pm
That is sweet. how does the ink hold up to handling?
Robert81
Male Number of posts : 65
Registration date : 2008-11-21
Post by frank on Thu 11 Dec 2008, 4:08 pm
Great tutorial Paul, I'll have to try it. The tutorial for the wide white walls would be nice too, please
frank
Male Number of posts : 439
Post by Paul on Thu 11 Dec 2008, 4:18 pm
Robert81 wrote:That is sweet. how does the ink hold up to handling?
It dries pretty good but will scratch off with your finger nail, but so will paint!
...............and Frank I will do one soon as I get a chance.
Post by Bryce on Thu 11 Dec 2008, 4:53 pm
Thanks Paul - that's awesome. Very Happy
Bryce
Male Number of posts : 3329
Post by slowlylearning on Fri 19 Dec 2008, 5:50 pm
Awesome, will be trying this one as soon as i find my sisters gel-pen stash! Thanks Paul
Post by joe d on Tue 02 Jun 2009, 10:46 am
that's a great tip
l have been using the circle template for while
but the tip with the gel pens is just
perfect for the smaller white lines
and now you have solved the problem of red line tires
thanks heaps
joe d
Male Number of posts : 120
Registration date : 2009-05-17
Post by TomA on Tue 02 Jun 2009, 11:06 am
Great tip Paul! terrific The other colours look good too! Can't wait to see how you go about doing the wide whites. What a Face
TomA
Male Number of posts : 341
Registration date : 2009-04-19
Post by NosNut on Fri 05 Jun 2009, 1:36 pm
Good stuff !!
For wide whites, I've used Liquid Paper ball point
has lasted a few years & looks like rubber
A lot of kit blackwalls have a lip moulded in, can be carefully outlined around said lip, then fill in till you've got coverage - no template needed
Last edited by NosNut on Sun 07 Jun 2009, 7:18 pm; edited 1 time in total (Reason for editing : speling fix)
NosNut
Registration date : 2009-04-22
Post by NosNut on Sat 06 Jun 2009, 1:05 pm
These were blackwalls from AMT '58 Impala
A bit dirty looking now, due to floating around in
bottom of box for a few years
NosNut
Post by slowlylearning on Mon 30 Aug 2010, 3:49 pm
the last 3 old amt kits i baught did not have them in there! :O they had yucky fat, hollow things Sad
Last edited by slowlylearning on Mon 30 Aug 2010, 5:49 pm; edited 1 time in total (Reason for editing : im an idiot.)
Post by michael on Mon 30 Aug 2010, 4:21 pm
GREAT TUTORIAL
michael
Male Number of posts : 430
Post by Tillerman on Tue 31 Aug 2010, 11:17 am
Nice tip mate! Thanks.
Tillerman
Male Number of posts : 467
Registration date : 2009-05-04
Post by allan on Sun 29 Jul 2012, 6:06 pm
Very cool tip Thank's for sharing
Male Number of posts : 9660
Post by GothicKustomz on Fri 14 Nov 2014, 3:34 am
GothicKustomz
Registration date : 2012-10-18
Post by GothicKustomz on Sat 07 Mar 2015, 11:52 am
Man I'm glad I came back!!!!! I forgot all about this, as I pondered where I could find wide whites, for the Queen of the 4 horseman build I have going, Famine, yes I will share pix soon, but I'm so glad to be back, thanx for this post
GothicKustomz
Post by zenrat on Sat 07 Mar 2015, 8:07 pm
Wouldn't Famine have THIN whites?
Just a thought...
Very Happy
