1/12 Tamiya Datto 240ZG with "options"
Page 2 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Re: 1/12 Tamiya Datto 240ZG with "options"
Post by Guest on Sun 19 Apr 2009, 12:10 pm
Wot size nuts & bolts do ya use Greg, this datto is looking 1 cool car now looking forward to the finished model.
Dingo Cool
Guest
Guest
Post by ashb on Sun 26 Apr 2009, 6:39 pm
popcorn iagree wat size bolts even 1:8th scale cars dont have suspencion nice detail....
ashb
Male Number of posts : 179
Registration date : 2009-03-01
Post by stump on Tue 28 Apr 2009, 5:18 pm
Thanks Paul.. Very Happy
Many thanks to you Dingo and Ash as well.. Wink
The bolts/studs I'm using for the struts are some I've had for ages....diameter is .92mm with matching nuts.
I got them at a hobby expo we had in my local town about 7-8 years ago.....I've since got lots more from a place in
the U.S. @
ScaleHarware Price seems reasonable and quality is fantastic....I'm using smaller bolts from them to mount
the over-fenders...make it easy to paint, and wont need glueing.....
Laughing
Small update...
Progress is still happening, though it's mainly been on tyre #2...the rear. I have the main shape formed, sidewalls and tread layer all sanded.
I started adding the tread pattern but managed to stuff it by going off centre....
Rolling Eyes So I need to remove the tread on half the tyre and re-do it....
I have the G-nose all mounted, some minor sanding and re-shaping was necessary to get a good fit...
Also got the new radiator panel in place and drilled some holes, as per 1:1 reference I have....Firewall also mated top and bottom.....all one piece now.
Bad joins.....
Better joins.....Radiator panel also visible in this shot....
Been thinking induction too.....it was between the stock twin SU's, triple Solex, or fuel injection.......
These won.......
Now, I don't have a manifold for these bad boys....so I started making one.....
Got as far as this, but was not overly happy with it......so I started another one......
Then.....over the weekend, I scored the Safari version off ebay....... Laughing It has the manifold I'm missing, along with some NEW carbs.....
When it arrives, I'll pilfer the required parts for this build, the Safari car will then get built into a showroom floor stock 240Z with twin SU's....
Cool Wink
With some luck and good management, I may get the rear tyre finished this week...or next, then they will be shipped off to a caster......
Stay tuned.........and thanks heaps for your grate support guys.
Greg
stump
Male Number of posts : 172
http://public.fotki.com/Greg5000/
Post by Kane on Tue 28 Apr 2009, 7:35 pm
The struts are very cool.
Post by ashb on Tue 28 Apr 2009, 7:55 pm
in one photo could you plese put a 30cm ruler next to it so we can see how big it is it looks like a 1:8th scale nice flares on mud gards popcorn still gana be one awsome build...... bigthumbsup
ashb
Post by Paul on Tue 28 Apr 2009, 8:59 pm
Good stuff Greg bigthumbsup
Post by TomA on Wed 29 Apr 2009, 12:57 pm
Coming along well Greg. Loving the detail! greatwork Thanks for the tip on ScaleHarware. I might have to order some gear from them on some of my next larger builds.
Keep up the good work mate.
Cheers, Tom
TomA
Male Number of posts : 341
Registration date : 2009-04-19
Post by truges on Fri 01 May 2009, 5:29 pm
The craftsmanship in this is fantastic! I love those wheels - looking forward to seeing it all come together.
Post by ashb on Fri 01 May 2009, 5:57 pm
bigthumbsup popcorn
ashb
Post by stump on Mon 11 May 2009, 9:53 pm
Thanks very much guys... Very Happy
Ash, I haven't got a pic with the 30cm rule yet, but the kit is 35cm long........ Shocked Wink
Update...
Ok...moving right along their folks....
I've turned my attention to the suspension again......The sloppyness of the joints was too much for me to bare......
The instructions call for the two rear upright halves to be glued around the control arm....being ever so careful not to let glue contact the movable part......
Shocked
Even after assembly, the joint is really quite loose.......not good ! I've circled the parts in red.....
I jumped in (who reads or follows instructions anyways... Rolling Eyes ..) and glued the parts before assembly....I let it dry completely before the next step..
I drilled the bore to accept a plastic rod, into which I would add some small bolts.
I then cut out the part of the control arm, no longer required..and drilled some holes to take the bolts..
Finished component.....No more free play, and it is much stronger...yet still allows full movement.....
Now that I was happy with that, I could see that the front was going to let it down.....The movement (unwanted) in the front control arms was worse... Crying or Very sad
The two mounting pins, one on either side, were trimmed off...In their place, I drilled a hole. Yes, more bolts. Very Happy
Testing on an old suspension piece.....
Complete, ready for installation......
I also thinned the ends of the control arm stays, threaded on some nuts...so I'll be able to attach it all firmly once she's in....
That's all for now guys, thank you all for your following and encouragement....
Wink
Greg
stump
Post by Paul on Mon 11 May 2009, 10:17 pm
Nice! popcorn
Post by zenrat on Tue 12 May 2009, 1:56 pm
You can't see me but i'm shaking my head in disbelief.
Good work mate.
It might be leaping ahead but have you put any thought to working wipers, washers and door latches?
Post by TomA on Tue 12 May 2009, 4:49 pm
You're really going at this one Greg. coolman Nice fix on the suspension! You going to gas the shocks too? Rolling Eyes
TomA
Post by zenrat on Wed 13 May 2009, 1:00 pm
Actually, working washers wouldn't be too hard to do. you could use a rubber bulb hidden in a base as a pump.
Post by Rocket on Fri 15 May 2009, 8:47 am
slap .I'm still Shocked .this things looking awesome
Rocket
Number of posts : 424
Registration date : 2008-03-28
Post by stump on Sat 16 May 2009, 9:29 am
zenrat wrote:You can't see me but i'm shaking my head in disbelief.
Good work mate.
Shocked .... Laughing
Thanks Fred....there ya go, filling my head with more great ideas...... Laughing
Actually, door latches may happen.....I'm looking into them anyways....having just received my Haynes Datsun manual... Wink
Tom,
Not sure on gassing the shocks....
Laughing ..the springs will hold up ok, I hope...
Thanks Rocket...I need to nail a paint job like one of yours mate.....this may be my downfall..... Sad
Greg
stump
Post by Rocket on Sat 16 May 2009, 10:05 am
6 P's mate, Prior planning prevents piss poor performance. In other words do your reaserch talk to spay painters if you have to practice on what ever you can get your hands on and experiment. if you need any tips and advice give us yell. Wink
There no such thing as stuff up it's just a challenge. Laughing
Rocket
Post by stump on Sat 16 May 2009, 11:35 am
Rocket wrote:6 P's mate, Prior planning prevents piss poor performance. In other words do your reaserch talk to spay painters if you have to practice on what ever you can get your hands on and experiment. if you need any tips and advice give us yell. Wink
Cheers mate. I LOVE that philosophy....and shall head your advise.
At least it will be easier to see what's going on, paint wise....and see the flaws, allowing time for fix-ups...
Greg
stump
Post by tezza43 on Sat 16 May 2009, 9:04 pm
I'm really enjoying the great workmanship going into this build. Thanks for putting more ideas into my head for future builds.
twothumbsup
Post by stump on Sat 23 May 2009, 4:54 pm
tezza43 wrote:I'm really enjoying the great workmanship going into this build. Thanks for putting more ideas into my head for future builds.
twothumbsup
Laughing ..Thanks Tezza, glad you're enjoying it mate.
Update, May 23rd...
Well, the rear tyre is still in progress...though it now has 3/4 of the tread added....Man, that's fiddly....
Rolling Eyes
Also got to thinking, how I was going to attach the exhaust system...seeing as I cut off the ugly giant mounting pins from it.... Wink
I wanted to stay within the boundaries of realism, and also knew that, as this was not a "stock" system, a little artistic expression could be used.....
Being a large diameter pipe, I felt that a mid support could be an advantage....This will be mounted with a "rubber" joint, to absorb movement..
In the rear, I made up an "L" bracket of sorts....The U-bolt is scratched up as well. It all bolts to the chassis..
The bracket by its self, and a group shot of the parts....
And a rear shot, looking towards the front...
Also started fabricating a new fuel tank and spare wheel well for the second Datto..though they may go onto this one.. Wink
I hadn't considered this fact when my original plans for the Safari version were to return it to "stock"....so, either way, a new tank and wheel well need to be made... Embarassed
More soon guys, and thanks for enjoying this as much as me....
Very Happy
Greg
stump
Post by Tubman on Sat 23 May 2009, 6:07 pm
Yep, just confirmed it, you are a seriously sick and twisted man Greg Shocked , probably a good thing mate, no sane person would go to this much trouble rolf , nah, seriously mate, that is awe inspiring. When it's finished I'm going to need a couple of hours alone with it just to absorb all the detail. Fantastic. I'm trying to put some I have learnt from your builds into 58 SD but as mine is a full on show car a lot of stuff will be hidden......yeah that's my story anyway Suspect
Post by Paul on Sat 23 May 2009, 7:22 pm
More great craftsmanship there Greg, looksgreat
Post by Rocket on Sun 24 May 2009, 6:25 pm
:study: drooly . sorry lost for words right now.
Rocket
Post by TomA on Tue 26 May 2009, 2:56 pm
Greg, I'm p1ssed and amazed! Shocked So much detail in 1/12th scale. I magine a 1/8th build!!! wowwee This IS craftmanshp at it's best and the scratchbuilt bits look so bloody real!! yourock
TomA
Post by stump on Wed 27 May 2009, 5:01 pm
Thanks Tubbs... Laughing Thank you too Paul, Rocket and Tom.. Very Happy
Tom, I can see a 1/8 hot rod in my future.....fair ways down the track, but one I'd love to do...
Update....
Well, the fuel tank and wheel well are shaping up.....Because I've made good headway on them, I'll use these for this build..
That way, I can keep the good kit parts for the stock version....
Wink
The start.....
Taking shape.....
Almost......the wheel holder has had more work since this was taken...
I'll run a duel fuel lines from the tank, along with twin filter/pumps just in front of the tank....
Just some more tidying up to do, then I can give'em a squirt of primer.....
More soon guys..
Greg
stump
