XE Falcon S-Pack ** wheels rolling on dusty roads **
Page 35 of 36 Previous  1 ... 19 ... 34, 35, 36  Next
Re: XE Falcon S-Pack ** wheels rolling on dusty roads **
Post by Carps on Tue 23 Dec 2014, 10:30 pm
Brilliant work! bigthumbsup
Male Number of posts : 3160
Post by aussie muscle on Wed 24 Dec 2014, 11:18 am
I fade the tires with a light wash of Dust (off-white) acrylic that came in my weathering set. it gives them a slight grey colour that seems about right. alternatively a wash of black and dark brown to give it a road grime look.
very bad tires:
Grimy tires:
DeeCee wrote: i know that weathering is a lot harder than making the buggers shine, great job mate.
I find that hard to believe. i've done plenty of convincing weathered cars, but never able to get a flawless showroom look.
Post by mouse on Thu 25 Dec 2014, 5:06 pm
wow I'm lost for words
mouse
Male Number of posts : 151
Post by ShawnS on Sun 04 Jan 2015, 8:47 pm
Happy New year all.
Still pondering the tyre weathering for the trailer but there is more work on the body to show you.
Lets start with the interior roof.
I made the sun visors, light and grab handles.
It's been a long time since I showed you a how-to for anything so here's a quickie for making many of the same type of flat part.
Cut the styrene pieces to slightly larger than the final size.
Using small drops of super glue, glue the pieces to each other.
Carve, grind and sand the block to the required shape.
Separate the parts with a sharp blade then clean them up as required.
I did the sun visors in the same way.
The next challenge was to get the window glass to sit closer to the outside of the window frame. The only way to do this was to alter the thickness of the pillars around the inside of the frames. I also decided to add a filler piece inside to create a channel for the clear styrene sheet to sit in.
Ditto for the rear windows.
The clear styrene window pieces shaped and ready to go. I decided to have both rear passenger windows fully wound up, the front passenger window wound down 2/3rds and the drivers window fully wound down.
Even after 4 years things still turn to crap. I had to strip and re-spray the primer on the body after it went soft when I had to handle the body frequently during the work on the interior. All went well until an unexpected gust of wind (on a calm day) sent the body on a 3ft downwards trip to the cement path causing damage to the rear trim around the tail lights.
Here's how I fixed that. I stuck some Tamiya tape underneath the tail light cut out and mixed up some talc and superglue and slapped it on to the damaged area.
When the glue set I removed the tape,
and shaped the area to suit.
Good as gold
I hit the body with Tamiya TS-46 light sand for the base coat.
Mixed up some beige using Tamiya TS-7 Racing white tinted with TS-16 Yellow and AS-22 Dark earth to make a pale caramel colour.
The first coat was sprayed today.
In case you were wondering what Bahama beige looks like here are some samples.
That's it for now. Very happy to finally get that first coat of paint onto the body after such a long wait.
CheersSS
ShawnS
Male Number of posts : 528
Post by DeeCee on Sun 04 Jan 2015, 10:28 pm
AWESOME WORK SHAUN!!!!
This build has been mind blowing all the way through, but to see it looking like the real thing,
at the end of the build,........ just AWESOME!!!!!
Post by allan on Mon 05 Jan 2015, 9:49 am
WOW great colour on it. bigthumbsup
Male Number of posts : 9545
Post by ShawnS on Tue 06 Jan 2015, 4:09 pm
DeeCee wrote:AWESOME WORK SHAUN!!!!
Thanks Dale but she's nowhere near the end of the build yet. With 2 of the buggers under construction I figure it's about 1/3 distance at the moment.
ShawnS
Post by Gabosamu on Thu 15 Jan 2015, 9:54 am
I want to be like you!!! And I was feeling good for modifying one of revellīs prepainted camaros... Youīve got a gift!!! Keep up the hard work!!! hope to see it finished soon, I havenīt read all of the comments, but how much time have you been working on this?
Gabosamu
Male Number of posts : 21
Registration date : 2014-12-04
http://www.renderosity.com/mod/gallery/browse.php?user_id=93886
Post by Deaf as on Thu 15 Jan 2015, 4:26 pm
Great work Shawn, this is just unbelievable! Words fail me!! Shocked
Male Number of posts : 1130
Post by ShawnS on Thu 15 Jan 2015, 7:51 pm
Gabosamu wrote:, I havenīt read all of the comments, but how much time have you been working on this?
Thanks for the kind words Gabosamu. The first post of this thread was in April 2011 but I started it late March 2011, so it's been four long years so far.
ShawnS
Post by Gabosamu on Fri 16 Jan 2015, 7:38 am
Itīs been worth the time, it looks really amazing, Iīve been stuck also with "my return" to scale models, I bought that camaro on december 23rd and Iīm barely 50% of what I want it to look like, You have a looooooot more patience than me, I donīt know if I can wait that long on a single built, hope youīre painting some other models, but I repeat itīs been worth every hour on it.
Gabosamu
Post by allan on Mon 23 Mar 2015, 7:11 pm
Hows this one going popcorn
Post by ShawnS on Mon 23 Mar 2015, 7:59 pm
uuhhhhggg. Don't ask. It's been a bastard of a summer. I got as far as finishing the final colour coats and laying down the first clear coat and after that I found that every time I was free to do the final clear coats the weather wasn't ready for me and I had to abandon any painting plans. I think we have had the longest run of windy days here in Southern Adelaide on top of the regular hot and/or humid days that we usually get.
I have found it fairly hard to get motivated to kick off again but I think it's just a temporary setback. The project isn't abandoned it's just slightly stalled.
CheersSS
ShawnS
Post by nosaj76 on Thu 26 Mar 2015, 11:27 pm
Love the tips and tricks mate about the glue and talc!..Pardon my ignorance but what is the theory behind mixing Windex with your paint? Keep up the good work.
nosaj76
Male Number of posts : 104
Post by ShawnS on Fri 27 Mar 2015, 7:16 pm
nosaj76 wrote:Love the tips and tricks mate about the glue and talc!..Pardon my ignorance but what is the theory behind mixing Windex with your paint? Keep up the good work.
I was surfing through youtube trying to find tips and tricks for airbrushing acrylic paints and I stumbled across a guy who was using Windex to thin the acrylics he was using. As I didn't have any acrylic thinners on hand I thought I'd give it a go. It's not for every situation but it worked for the gold paint I used on the trailer. Pretty handy for cleaning the airbrush too.
ShawnS
Post by allan on Fri 27 Mar 2015, 7:29 pm
I seen that too using windex for airbrushing acrylic, I picked up some Italeri acrylic paint its made by Vallejo. Found metho works too with both paints and is cheaper to use. Oh if you make a mistake with the paint it washes off with metho too. I use metho with the small bottles of Tamiya acrylic too. Oh one thing to watch for if you are airbrushing with metho as a thinners on a cold day you can end up with metho freezing in the paint and it goes patchy and airbrush can freeze,
Post by zenrat on Sun 29 Mar 2015, 3:49 pm
Thinning acrylics with metho makes them dry real quick which may be good or bad depending on what you're doing.
Male Number of posts : 6830
Post by allan on Sun 24 May 2015, 2:33 pm
Post by mgy125 on Sun 24 May 2015, 4:25 pm
You are truly in for the long haul on this project.  It is getting closer with every post.  Hang in there. You do nice work.
Post by allan on Fri 17 Jul 2015, 3:16 pm
How's it going with this one. popcorn
Post by ShawnS on Fri 17 Jul 2015, 4:29 pm
The break from the build has collided with the usual winter break to form a super black hole of bugger all. scratch So the answer to your question Allan is--  not much mate. I've not really been doing anything model related lately, just not in the zone at the moment.
ShawnS
Post by allan on Sat 18 Jul 2015, 10:22 am
Ok than will be watching and waiting for a up date in time.
Post by min16i on Wed 22 Jul 2015, 5:36 pm
Stay with it Shawn,
I'm sure I'm not the only one who has been inspired by this monumental project. I re-read it the other night just because it was here.
We will just have to wait for the seasons to change, and the mighty Falcon will once again spread it's wings.
That was a bit deep wasn't it lol
Ian
min16i
Male Number of posts : 34
Registration date : 2013-04-01
Post by ShawnS on Thu 16 Mar 2017, 8:27 pm
Hi again.
 So here I sit in the mother(f****r) of all slumps and I began pondering the future of this build and I've started thinking that perhaps I'm going about it all in the wrong way. Maybe I'm stalled because I am too personally attached to the 1:1 cars I am trying to replicate and the pressure I am putting on myself to do my memories justice is putting the bigger picture out of focus. What do I do about it ? Which direction should I head ? I started thinking about a slump buster build. What should I build ? More thinking.. Question Question Question Question
 I opened a box the other day wondering why it was there and what was in it and I found the third XE Falcon body/chassis and complete set of parts that I cast a couple of years ago and I was thinking maybe I should bust my slump with a Falcon that I am not attached to. Perhaps I should keep it simple without too many extra details and concentrate on the often forgotten skill of finishing a model essentially as a test run for finishing the two main builds.
I haven't made a final decision yet just thinking out loud.
Your thoughts as always are welcome.
CheersSS
ShawnS
Post by DeeCee on Thu 16 Mar 2017, 8:32 pm
Shaun, sometimes it just takes a good fun build to break that slump mate.
Drag out one of those bodies, slap a bloody big engine in it, a sweet set of wheels,
the right color... and before you know it, it's done!!! And you have finally finished one of your XE's..
Go for it, you can do it..
