'65 Tattoo Dancer
'65 Tattoo Dancer
Post by GothicKustomz on Fri 14 Jun 2013, 8:10 am
Yep I knew it, burn out! yea on the Twisted Intentions, was just a matter of time, so for, an inspiration build, "SIGH" I'm gonna do this one, I have everything i need right here, this will be sorta just outa the box, with a few scratch built things, ummmm sorta:
Using Windex as a dechromer, tho I'm sure ya could use Amonia, as that is the leading ingrediant in Windex, hmmmmmm, I got a jug of that too, should try it out see if it works:
Most of the suspension that will be scratch built, so keep an eye out on here.
I did use straight Amonia, it works great, tho it didn't take the gloss undercoat off, it only took about 15 min to dechrome, the part, I think I got a gallon jug of the stuff from the Dollar Tree, worth the investment.
GothicKustomz
Registration date : 2012-10-18
Re: '65 Tattoo Dancer
Post by GothicKustomz on Fri 14 Jun 2013, 8:13 am
Dechromed, using straight Amonia, now if you go this route, use a toothbrush to scrub, right out of the amonia bath, the old under clear coat came right off, sat in the amonia about 2-3 hours, then rinse, and wash using dish detergant.
GothicKustomz
Post by GothicKustomz on Fri 14 Jun 2013, 8:45 am
OK body smoooooth, and ready to french the taillights, I'm using a stir straw from my local circle K store.
GothicKustomz
Post by Jade043 on Fri 14 Jun 2013, 11:45 am
Will keep an eye one this one I could learn something
Post by zenrat on Fri 14 Jun 2013, 12:12 pm
IIRC metal + base = salt + water.
So you are making some sort of chromate solution there.
I've not seen this release of the '65.  Decals look good.
Post by kevjoh on Fri 14 Jun 2013, 5:31 pm
White King bleach from Wollies works OK as well
kevjoh
Male Number of posts : 328
Post by mutley on Fri 14 Jun 2013, 7:37 pm
spellcheck broke Kev?
Male Number of posts : 336
Post by GothicKustomz on Sun 16 Jun 2013, 8:06 am
OK, gang, here she is, in her first coat of primer, as u can see the frenching went very well, just a few things to clean up, soon as it sets up I will post with the tailights in
GothicKustomz
Post by GothicKustomz on Tue 16 Jul 2013, 9:38 pm
FINALLY! first base coat, now to wet sand, and then mask off, then on to second base coat:
GothicKustomz
Post by DeeCee on Tue 16 Jul 2013, 9:46 pm
Nice deep silver flake mate, frenching came out well too.bigthumbsup
Post by GothicKustomz on Wed 17 Jul 2013, 4:08 am
Phase 2:
GothicKustomz
Post by DeeCee on Wed 17 Jul 2013, 5:49 pm
Nice start with the fades mate, now for the tricky bits.Laughing  Looking forward to it.
Post by Clutch on Mon 19 Aug 2013, 8:04 pm
Nice metalflake fade, should really sparkle in the sun.
Male Number of posts : 1310
