Salt Flats Roadster
Page 2 of 5 Previous  1, 2, 3, 4, 5  Next
Re: Salt Flats Roadster
Post by dpride on Fri 30 Aug 2013, 9:58 am
Thanks for comments guys.
I have modeled the front wheels to be printed.
Now I have to find some more real work to pay for it. Rolling Eyes
dpride
Male Number of posts : 80
Registration date : 2012-11-05
Post by mgy125 on Fri 30 Aug 2013, 10:30 am
dpride wrote:Thanks for comments guys.
Isn't that always the problem...work that pays real money.
Post by zenrat on Fri 30 Aug 2013, 12:05 pm
Every time I look at this I think it wouldn't be much more work to make it run.
Post by silverfox on Sat 31 Aug 2013, 8:55 am
Great work on this , your skills are amazing.
Post by allan on Sat 31 Aug 2013, 9:15 am
Justed picked my jaw up off the floor, thats one super cool engine  bigthumbsup
Post by dpride on Tue 03 Sep 2013, 6:18 pm
Thank you all.
Most of the front axle done, built from steel tube, stainless tube, and aluminum.
Some of the fasteners are temporary.
dpride
Post by mgy125 on Tue 03 Sep 2013, 6:32 pm
Just keeps getting better and better.
Post by dpride on Tue 10 Sep 2013, 2:26 pm
Some work on the shifter, loosely patterned from a Hurst unit.
Threaded rod runs through entire engine to tie it all together (for strength).
Made of aluminum, steel and brass.
Still some components like stops and clips to be made.
dpride
Post by allan on Wed 11 Sep 2013, 3:23 pm
wow popcorn
Post by dpride on Wed 25 Sep 2013, 10:17 am
The body is out of the mold. The layup is done with vinylester gelcoat and resin. Two gelcoat layers and
two 225 gram CSM layers. Minimal shrinkage. Mold is brush on silicone rubber(2 coats) and quick plaster jacket.
After a trim,onto the chassis...
dpride
Post by mgy125 on Wed 25 Sep 2013, 12:20 pm
greatwork Impressive.
Post by dpride on Fri 27 Sep 2013, 8:21 am
Pictures of the body cleaned up. I did the Fiat body at the same time. The next job is to cast the rocker
covers in pewter. Anybody on the forum have any experience with casting metals for models? I have done
a bit of investment casting years ago. Both current builds have SBC engines. I don't want to go with centrifugal
casting as the molds are not viable (cost wise) for 6 pieces. Already have high temp rubber so maybe I'll
just have to experiment......Very Happy
dpride
Post by slowlylearning on Fri 27 Sep 2013, 12:34 pm
Brilliant stuff there mate! Loving watching this thread Very Happy
Post by dv8v8 on Fri 27 Sep 2013, 4:27 pm
i used to use lead in high temp rubber but its been a long time and the castings were simple one piece items, rekon rocker covers would not be too dificult if u cast them upside down with the bottom open to accept the metal, biggest problem i had was not burning holes in the kitchen benches, found a good sized piece of plywood was very helpfull !
Post by dpride on Sat 28 Sep 2013, 8:13 am
dv8v8....you're right about having the cover's opening facing up, I had thought if the 3mm thickness I have
as a wall thickness won't allow the metal to flow (with gravity) , I'll pour it solid and roughly mill out
the back to lighten the piece. The key is to get the right temp for both mold and metal and of course the
vents and runners.......guess I'll have to do it the long (right) way.Rolling Eyes
Lee melting pot and temp gauge VS oxy torch and a $1.97 kitchen ladle........
dpride
Post by allan on Sat 28 Sep 2013, 8:16 pm
That one cool roadster body,
Post by dpride on Sun 29 Sep 2013, 11:28 am
Mock up of major parts on chassis.
dpride
Post by allan on Sun 29 Sep 2013, 12:53 pm
like the super charge out the front  badtothebone
Post by doorslammerfan on Sun 29 Sep 2013, 2:09 pm
Superb workmanship throughout ! and thanks for explaining your processes
https://s1188.photobucket.com/albums/z410/doorslammerfan/
Post by dpride on Sun 06 Oct 2013, 5:47 pm
allan, the front mounted supercharger is to cut down on frontal area as the car will have a full nose section.
doorslammerfan, thanks....glad you appreciate the pics.
I have mounted the rear except shock top mounts. Chassis is oxy welded, some with filler, some 45% silver
solder. Also bent trans mount from 1/2" steel tube. Slot head screws are temp.
dpride
Post by allan on Wed 16 Oct 2013, 7:13 pm
WOW looking good
Post by dpride on Mon 25 Nov 2013, 5:49 pm
Made a few more parts for the roadster. The tires are taking longer than expected. Not much work recently so I can't spend a lot on printing masters for the wheels and tires. Guess I'll make them with what material I have.
Here are pics of progress so far.
Thanks for looking, more on the body next post.
dpride
Post by DeeCee on Mon 25 Nov 2013, 8:14 pm
WOW!! I don't believe this is a model anymore. Just can't be.Rolling Eyes Razz
Post by Bernard Kron on Mon 25 Nov 2013, 9:09 pm
DeeCee wrote:WOW!! I don't believe this is a model anymore. Just can't be.Rolling Eyes Razz
When you work to this scale I suspect you have to start making decisions as to whether things will actually function or not - we're treading in the gray area between "model" and "miniature"! This is simply beautiful stuff to be savored and enjoyed. I especially like the detail shot of the the join between rim and spokes on the steering wheel... Thanx for all this, David!
Male Number of posts : 462
Post by dpride on Sat 30 Nov 2013, 10:29 am
DeeCee, thanks, it's a big model so the detail is much easier.
Bernard, glad you like. When you build at this scale, some of the parts have functionality just by having to be strong enough to take the stress of the weight.
These models weigh kilograms, not grams.
A few more bits.....
dpride
