Citroen 15 CV
Citroen 15 CV
Post by dv8v8 on Sun 02 Feb 2014, 1:29 pm
this is my latest project, a Citroen CV 15 its a heller kit, its not quite what im used to, the front wheel drive setup was quite a challenge but now thats done i rekon the rest should be easy
Male Number of posts : 4956
Re: Citroen 15 CV
Post by DeeCee on Sun 02 Feb 2014, 1:52 pm
That looks pretty intricate mate, what does the body shape look like??
Re: Citroen 15 CV
Post by allan on Sun 02 Feb 2014, 2:04 pm
Now that's diffrent
Re: Citroen 15 CV
Post by dv8v8 on Sun 02 Feb 2014, 9:36 pm
the car reminds me of a 34 ford i will post more pics when i have more to show
Re: Citroen 15 CV
Post by zenrat on Sun 02 Feb 2014, 10:42 pm
Re: Citroen 15 CV
Post by warra48 on Mon 03 Feb 2014, 8:23 am
Always loved the look of this car.
What scale is your model? I know they also came out in a large scale as well.
warra48
Male Number of posts : 84
Registration date : 2012-02-13
Re: Citroen 15 CV
Post by dv8v8 on Mon 03 Feb 2014, 5:44 pm
its 1:24 scale
Re: Citroen 15 CV
Post by dv8v8 on Mon 10 Feb 2014, 10:54 pm
this one is certainly a challenge but im getting there.
Re: Citroen 15 CV
Post by Bernard Kron on Tue 11 Feb 2014, 1:39 am
Is the challenge in the fit of the parts? There certainly seems to be quite a lot of detail to work with. Nice job! I'm looking forward to seeing more...
Male Number of posts : 414
Re: Citroen 15 CV
Post by dv8v8 on Tue 11 Feb 2014, 6:45 pm
the parts look very fiddily and no where near strong enough, i have had problems keeping the assemblies glued together, they seem to fall apart very easily however once the assembly is complete its surprisingly strong, so far no major dramas just frustrating reassembling things, the rear axle has been attached 4 times, but untill the body and chassis are combined it remains a very tenous attachment.
Re: Citroen 15 CV
Post by dv8v8 on Sat 15 Feb 2014, 11:28 pm
patience is wearing thin with this one, hopefully the worst is over and its all downhill from here
Re: Citroen 15 CV
Post by bennyg on Sun 16 Feb 2014, 12:10 am
Different subject. Looks to be going together well.
Re: Citroen 15 CV
Post by chromecop on Sun 16 Feb 2014, 2:34 am
I started one of these kits about 25 years ago. Never finished it thou, and sold it about half built. You're doing a great job on this quite fiddly kit!
chromecop
Male Number of posts : 434
Re: Citroen 15 CV
Post by dv8v8 on Sun 16 Feb 2014, 12:59 pm
having got this far i began to assemble the front panels only to find that i have somehow missinterpreted an earlier diagram in the instructions ( should have thrown them away but the kit is so complicated i needed them! ) this has resulted in the mudgaurds sitting about 10mm too high, some dissasembly was done and refit attempted this only brought the gaurds down to 5mm too high and means that repainting is now required ( this will be difficult considering how much is now assembled) after getting the left side to sit right i attempted the right but nothing i could do would get the gaurd to sit flush along the side of the body unless i moved the front end/engine/radiator assembly however this would then result in missalignment of the left side.....after much thought i decided to make some minor adjustments using a solid object and great force, this was somewhat succesfull as i no longer need to adjust anything, the rear tyre thingy on the boot fitted very well through the windscreen as it exited the vehicle and the location of many parts is now a mystery, although some have appeared in some very unexpected locations! the remainder of the parts are now resting in pieces in my spares box. DO NOT BUY THIS KIT its a waste of your time and money, i now understand why i have only seen one completed on this forum and that was done as a rusting wreck.
Re: Citroen 15 CV
Post by 70cudatj on Sun 16 Feb 2014, 4:28 pm
Bummer. But at least we are warned now, 10:10 for perseverance though.
Re: Citroen 15 CV
Post by DeeCee on Sun 16 Feb 2014, 8:28 pm
Should have HOT-RODDED  it mate, would have been easier by the sound of it.  Laughing
Re: Citroen 15 CV
