Cuda sports wagon
Re: Cuda sports wagon
Post by silverfox on Wed 09 Jul 2014, 11:54 am
Looking so cool , I really like that slime green colour .
Post by Jerry Ol'55 on Wed 09 Jul 2014, 5:11 pm
dv8v8 wrote:engine is done
This engine is looking awesome!...seriously how does one get that much
detail in regard to the plug leads from the dizzy to the plugs?.  I tried it and ended up
with a "Mush Mess" of bits of plastic, glue & wire!. I had another go using copper wire
then painted (ref: my Chuck Millers Fire Truck post - workshop), but even then it's not
great.   So how do you guys do it???... Jerry
Post by dv8v8 on Wed 09 Jul 2014, 6:33 pm
the dizzy is a resin one with pre drilled holes from The Parts Box ( have tried many times over the last week to place an order with them but keep getting a message saying the site is to busy!) i usually drill the holes out a bit more, then add the wires, the wires came from Paul ( i think) but are readily available from many parts suppliers, the wire usually comes with a piece of plastic tube to make the plug boots, generally i cut 9 leads of varying lenghts add the boots then superglue one end into the holes in the dizzy, the dizzy is then painted and when dry the boots slid down the wire untill they are correctly seated, the heads (or as in this case the valve covers) are then drilled with a fine bit (about .5 of a mill), the completed dizzy is then glued in place and then each of the wires are fitted, trimmed and superglued in place and the boots are slid down the wire. this is how i do it others may have a better idea, i know that some dizzy's come with the wiring already attached. hope this helps
Male Number of posts : 5006
Post by Jerry Ol'55 on Wed 09 Jul 2014, 8:04 pm
dv8v8 wrote:the dizzy is a resin one with pre drilled holes from The Parts Box ( have tried many times over the last week to place an order with them but keep getting a message saying the site is to busy!) i usually drill the holes out a bit more, then add the wires, the wires came from Paul ( i think) but are readily available from many parts suppliers, the wire usually comes with a piece of plastic tube to make the plug boots, generally i cut 9 leads of varying lenghts add the boots then superglue one end into the holes in the dizzy, the dizzy is then painted and when dry the boots slid down the wire untill they are correctly seated, the heads (or as in this case the valve covers) are then drilled with a fine bit (about .5 of a mill), the completed dizzy is then glued in place and then each of the wires are fitted, trimmed and superglued in place and the boots are slid down the wire. this is how i do it others may have a better idea, i know that some dizzy's come with the wiring already attached. hope this helps
Thanks so much for that info. it certainly finishes off the look of the engine. Will get the bits required and give
a real good go!.  Thank you again DV8. Cheers Jerry.
Post by dv8v8 on Sun 13 Jul 2014, 6:49 pm
finally got the paint to where im happy with it, its taken me a while and its a bit rough, but this is the look i was trying for.
Post by allan on Sun 13 Jul 2014, 9:07 pm
Thats looking good. A+
Post by DeeCee on Sun 13 Jul 2014, 9:10 pm
WOW!!  That is looking AWSOME!!!  Those Cuda stripes have really set this off perfectly mate,  LOVE IT!!!   bigthumbsup
Post by silverfox on Sun 13 Jul 2014, 9:14 pm
Looking great , another top build on the way .
Post by DumpyDan on Mon 14 Jul 2014, 4:11 am
That looks so sweet, can't wait til it is done...................Waiting and watching.
DumpyDan
Male Number of posts : 184
Post by dv8v8 on Fri 18 Jul 2014, 10:23 pm
a bit more progress
Post by Tubman on Sat 19 Jul 2014, 10:17 am
Looking good John.
Post by allan on Sat 19 Jul 2014, 11:19 am
Looking great, I would of left the roof all green and put black on the bonnet, still its a great wagon as is badtothebone A+
Post by Carps on Sun 20 Jul 2014, 5:21 pm
I'm diggin this one.  twothumbsup
