Recycled AC Mack
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: Recycled AC Mack
Post by allan on Tue 27 Jan 2015, 9:49 am
Like the way you have put the foil on the side once you have painted  it and weather it sould look like metal. popcorn
Male Number of posts : 9582
Post by zenrat on Tue 27 Jan 2015, 11:34 am
Coming along very nicely.
You build good scratch.
Post by bennyg on Sat 31 Jan 2015, 12:50 pm
Wow. Very cool project.
Post by Deaf as on Sat 31 Jan 2015, 6:10 pm
Thanks gents. Hope to get back into this soon.
Post by Deaf as on Sun 08 Feb 2015, 8:03 pm
I scratch built an air compressor for the Mack. The theory is that this will allow it to operate as a stand alone unit or as part of a train. The connecting rod from the bottom pulley into the body of the compressor is a Pitman? arm from a truck kit and the black filter  at the top is part of a Euro style brake booster.
The compressor will be belt driven with the drive coming from the shaft with the brown cap to the right of the compressor. This is the shaft for the drive sprocket on the other side. It's a fairly steep angle down to the pulley on the compressor which drives the piston. I'm not sure if all this would work in the real world but Heath Robinson was an optimist . The tank to the left is the main air reservoir  with the connecting pipe from the compressor. It's made from evergreen tube and those little plastic caps that you push into the cross in Phillips heads screws in kitchen cupboards. I still have more pipework, another air tank and brakes to go.
The steps up to the cabin level. Once I'm up to the painting/detailing stage, I hope to put some broken timber on each of the chains hanging at the bottom of the steps to represent a broken swing step.
I think the steps are from a T series Scania kit. I was going to go with chequer plate or timber but thought this offered something different  and added to the 'made from odds and sods' look.
Post by Jerry Ol'55 on Sun 08 Feb 2015, 11:57 pm
Post by allan on Sun 08 Mar 2015, 11:18 am
How's this one going.
Post by Deaf as on Sun 08 Mar 2015, 7:36 pm
Things are going slowly. Have the conveyor framework done and a gearbox/drive unit on it. Working on the braking system for it. I am sort of copying off a HO scale wagon but only having a narrow chassis means making changes/ making it up as I go. Will post some pics when it becomes clearer what's going on.
Post by allan on Tue 10 Mar 2015, 7:59 am
Post by Deaf as on Sun 15 Mar 2015, 7:38 pm
Have got a basic braking system on this. It ended up lower that I wanted but needed it to be so to clear the conveyor.
Realistically where I have the chian linkages running from the centre pivot bar, it would probably be rods. I felt the chains added an extra dimension and texture.
I still need to run a bit of pipework around the valves on the red tank and up to the underside of the cab floor.
Front end view of the conveyor showing the gearbox.
Side on view. I'll keep this as a separate assembly so it's easier to put the belt on once painted.
I've used the mechanism from the landing legs of a semi to represent the gearbox/transfer case coming from the pto shaft on the axle. I'll use a drive shaft with uni's at each end to drive the conveyor.
Post by allan on Mon 16 Mar 2015, 9:01 am
AWESOME work on it. A+
Post by bennyg on Wed 18 Mar 2015, 12:51 am
Great work. Look forward to more.
Post by kevjoh on Tue 14 Apr 2015, 9:10 pm
Great work, after seeing it in the real I'm amazed at the amount of detail.
You've got more patience than I've got. great to catch up on the week-end
kevjoh
Male Number of posts : 328
Post by Deaf as on Sun 19 Apr 2015, 1:10 pm
Thanks Kev and yes it was good to catch up again. I've started  with the basic paint on this.
This is my first go at using the hairspray method to weather the paint. I used grey etch primer and let it dry off then hit it with Tamiya acrylics to do the rust/brown and black spots. When that was dry, I hit it with hair spray and then the Tamiya top coat when the hair spray was barely dry. As the top dried, I rubbed it with a wet brush and cotton tips to expose the underneath colours. With a bit more practice I'd reckon it would come up better. Seems to work better with flat paints. The truck chassis was gloss red and tended to peel rather than rub through.. Going to detail the weathering with pastel chalks, another first but Muttley said it's easy so what could possibly go wrong?? Apparently it wipes off with your finger if you're not happy with it, mind you, I've had paint do that too!
Post by zenrat on Sun 19 Apr 2015, 3:39 pm
This has to be seen in the flesh.  It's great.
I've just tried my first attempt at hairspraying (Acrylic over silver car paint) and I found that it was all too easy to rub off more of the acrylic than I intended.
Post by Deaf as on Sun 19 Apr 2015, 8:37 pm
Thanks for the kind comments guys. The hairspray technique takes some getting used to and yes, it is easy to take way too much off, right back to the foil based on todays effort. Painted the chassis and hopper today. Will put pictures up when it dries.
Post by Deaf as on Mon 20 Apr 2015, 7:24 pm
Basic colours on everything now. Still loads to do but can start putting it all together as I get bits finished. It's amazing how much stuff you discover you haven't done when you think it's all ready to go doh
Going to have a fiddle  with inks or oils or what ever I can find to make the timber decking look aged when I get to it.
Post by DeeCee on Mon 20 Apr 2015, 8:51 pm
HOLY COW!!!!!!
Not being a truck person, or truck builder, i do not think to look in here very often, man, i should, way more often.
This build is just amazing mate, the scratch building and detailing is awesome, my hat goes off to you,
this is just AMAZING.. bowdown
Post by Antwon on Mon 20 Apr 2015, 10:06 pm
I love the rusty ones..........................just amazing Tim.
Excellent building skills.
Post by Deaf as on Thu 23 Apr 2015, 5:47 pm
Thanks guys, a lot of first time stuff going on here - so far so good I think?...
Post by kevjoh on Thu 23 Apr 2015, 5:58 pm
"First time stuff" can be a bit of a nerve wracking experience!!!!!!!!!!!!!!!
The real bummer is when it turns out perfect first time then stuffs up the second time!!!!!!!!!!!!!!!!!!!!
It all looks perfect to me, what type of paint are you using?
kevjoh
Post by Deaf as on Fri 24 Apr 2015, 5:36 pm
How true Kev, just when you think you have it mastered it goes to rubbish. I've been using Tamiya acrylics on this both for the airbrushing and brush detailing. Been great so  far, put a bit at a time in an old, clean milk bottle lid for the detail stuff then add the next colour for blending, bit of acrylic thinner in it for "washes" etc.
Post by aussie muscle on Mon 27 Apr 2015, 3:01 pm
Loving your work on this.
Deaf as wrote:with Tamiya acrylics to do the rust/brown and black spots. When that was dry, I hit it with hair spray and then the Tamiya top coat when the hair spray was barely dry. As the top dried, I rubbed it with a wet brush and cotton tips to expose the underneath colours. With a bit more practice I'd reckon it would come up better.
a slight variation i've used is the salt technique. after the rust brown layer, sprinkle salt in areas of heavy rust, then lock it down with hairspray and then top coat. the salt gives it a more natural textured, flaky look.
http://www.thepartsbox.com/BB/viewtopic.php?f=252&t=4715&p=72106&hilit=terror#p72015
Post by Deaf as on Sun 10 May 2015, 5:43 pm
Love the tow truck aussie muscle. The weathering came up a treat. I've put the hungry boards on the hopper and rear decking is on. I put a shaped piece of Styrofoam in the hopper and painted it flat black. The load is screened ash from a coal fired boiler.
I tried various methods to give the boards an aged look and found the best was just Humbrol primer grey thinned down, brushed on and wiped off. Mutley suggest oils but Beary crafty had nothing suitable in her stash so I'll chase that up next time.
I used the Dremel to thin through the seat cushion and the  used the knife to 'tear' the plastic. I then covered it with tissue, painted with acrylics and used offcuts from teddy bear fur to poke through the holes. I wanted it to look like it was on its last legs with the horse hair stuffing from a previous patch up job poking through.
Post by allan on Sun 10 May 2015, 6:08 pm
WOW looking good. A+
