1956/-57 VW Baja Bug
Post by chromecop on Sat 08 Nov 2014, 4:35 am
A couple of weeks ago I started a new VW build. This time a 1956/-57 VW (from Gunze) which I'll combine with a cirka 1968 Baja body from Kyosho. Here You can see what I started with:
First I stripped the prepainted Baja body and tested it using some desert tires from LOSI:
Next step was to cut of the entire front piece from both bodies and then narroe the Baja front using a wedge cut to make suit the Gunze body.
Even though I narrowed the front , I still had to widen the body about 1 mm below the windshield:
Then I cut off the rear fenders and air-spoiler:
And now, here's what it looks like all mocked up on the table:
It'll have sand-paddle tires in the rear and desert tires up front:
As I want this build to look a bit 70:ish, I prefere to use drum-brakes and I found a nice set of finned drums in my large box of spare parts:
chromecop
Male Number of posts : 434
Re: 1956/-57 VW Baja Bug
Post by chromecop on Sat 08 Nov 2014, 4:39 am
Today I've been doing some more work to the body. These Gunze VW's are supposed to have a black "rubber gasket" around the windscreen. I make the gasket from strip styrene instead:
I also cut of the small marked area where the front lic.plate is supposed to be and then put a piece of plasticcard in from behind the front:
chromecop
Post by allan on Sat 08 Nov 2014, 8:51 am
Looking good so far. popcorn
Male Number of posts : 9583
Post by chromecop on Sun 09 Nov 2014, 4:46 am
Made some progress today as well. Started modifying the front suspension. Cut down the stock axle and did some minor mods and then added new shocks:
I also found a decent pair of chairs in an old Revell Chevy kit. I just cut off the headrests. They will mount on VW stock support:
Steeringwheel from my stash:
chromecop
Post by allan on Sun 09 Nov 2014, 8:40 am
Cool Dak Dak in the making bigthumbsup
Post by chromecop on Sun 09 Nov 2014, 9:29 am
Thanks !
chromecop
Post by DeeCee on Sun 09 Nov 2014, 9:33 am
WOW, there is some great work going into this bug, should be a real beast.  (although i did like the black body you started with).Smile
Post by chromecop on Sun 09 Nov 2014, 10:28 am
Thanks! Well, actually there was nothing wrong with the black RC-body, but I've Always loved ovals and splits! Also, the RC-body is available in resin from a caster in the US and I didn't like the idea of people thinking I'd built a resin Baja ! Embarassed
chromecop
Post by chromecop on Mon 10 Nov 2014, 12:45 am
Front axle/suspension almost finished:
chromecop
Post by chromecop on Mon 10 Nov 2014, 8:15 am
Front end's been completed:
Also made "fake" turnsignal Arrows in the B-post:
chromecop
Post by mgy125 on Wed 12 Nov 2014, 7:04 pm
Nice.
Post by chromecop on Sat 15 Nov 2014, 5:29 am
I just had to do Another mockup after gluing the front and fenders to the Gunze Body and this is just about what it'll look like when finished:
chromecop
Post by allan on Sat 15 Nov 2014, 8:26 am
bigthumbsup popcorn
Post by Deaf as on Sun 16 Nov 2014, 9:40 am
Jeez Darryl, nearly as much work in this as restoring a real one! Looking good, what colours do you have in mind?
Post by chromecop on Sun 16 Nov 2014, 9:54 pm
Deaf as wrote:Jeez Darryl, nearly as much work in this as restoring a real one! Looking good, what colours do you have in mind?
Thanks! Colour will be L87 Pearl White and grey fabric sunroof + interior. This will be a "Herbie" Baja !!!
chromecop
Post by grease monkey253 on Sun 16 Nov 2014, 11:48 pm
Looking good mate , Glad to see someone else building a baja bug , i have started a bug eyed baja as well a couple of years ago buts its still ongoing . mine will be 1/24 version of tamiya's R/C sand Scorcher.
grease monkey253
Male Number of posts : 190
Registration date : 2010-06-27
Post by chromecop on Mon 17 Nov 2014, 1:45 am
That sounds really cool! I love that blue/White Sand Scorcher but found out that there's been very few Baja Bug's built in the "Herbie style" , so that's what made my mind up Wink
chromecop
Post by ozmodeler on Wed 19 Nov 2014, 6:59 pm
I like where your goin with this bug. keep up the great work man.
Post by chromecop on Sat 22 Nov 2014, 8:41 am
Made a Little progress today. Not much but still... Embarassed
chromecop
Post by allan on Sat 22 Nov 2014, 7:06 pm
Post by chromecop on Thu 27 Nov 2014, 4:58 am
Now, there's a hole in the roof and I've widened the chassie a Little just behind the front Wheels.
chromecop
Post by chromecop on Sun 30 Nov 2014, 2:56 am
This week I only had one day off work, so I really didn't have much spare time for modelling. However, I did manage to get a couple of hours in the mancave and here's the result. I've started scratchbuilding a Porsche Fan shroud for the engine, partly from a Fujimi Porsche and some other scrap parts (from a 1/8 scale Honda 750 cc bike!!!!)
As I didn't like the stock "firewall" i cut it off, and replaced it with a somewhat modified piece from another VW-kit:
I also found a simple roll-bar in my stash:
chromecop
Post by allan on Sun 30 Nov 2014, 9:10 am
Going to be a cool Dak Dak Bug popcorn
Post by chromecop on Sun 30 Nov 2014, 10:55 am
Thanks alot! i hope so to! Embarassed
chromecop
Post by chromecop on Mon 08 Dec 2014, 9:45 pm
I made some progress last night. Still not sure if this Engine will be used as I have a Porsche Turbo Engine on it's way home. It was given to me from a kind fellow modeler in Belgium! Thanks Marc!!!!!
chromecop
