A/Fuel Front Engine Dragster - Enderle Injected BBC Power - 13-06 Update
Post by Bernard Kron on Mon 01 Jun 2015, 10:20 am
There are certain subjects I keep returning to repeatedly as my skills and techniques evolve. One is the í32 Ford, in particular the various Revell Deuce kits, and the other is the classic early to mid-sixties front engine dragster, in particular the super-light, super quick Junior Fuelers. In the second case my preferred base kit tends to be the MPC Ramchachargers Dragster kit. I like the ultra-low legs-under rear axle stance and the just-right proportions of its 160Ē wheelbase chassis.
Iím always thinking about my next dragster but these days I only seem to build one every 12 months or so. Now is that time, and this one wonít quite be a Junior Fueler, although Iím using the Ramchargers kit. This time Iím running a Big Block Chevy instead of the small block motor that was de rigeur if you were running a Junior Fueler back in the day (310 c.i. limit). This is because of a really pretty Enderle fuel injector setup I bought from Speed City Resin a while back. It only fits the Chevy Big Block so, BBC it is!
With this project I decided to experiment with large area decals to create a fogged panel style paint job. The underlying color is DupliColor Metalcast metallic Ground Coat which is a near perfect 1/25th scale silver metalflake. If you print homemade decals on an inkjet printer you will quickly realize that the colors are very transparent and the base color shows through strongly. So inkjet color decal + silver metallic base coat = kandy color. Using Photoshop I made decals to create the fogged panel paint job I was thinking of. It took some experimenting but the technique works quite well. This one is very simple but now that Iíve figured it out I think Iíll be using it some more.
Below are a couple of composite pictures. The first one shows the Western Manufacturing Special body shell from Altered States Models I used, and the Enderle injectors from Speed City Resins. The second shows the decal layout I made and the decals applied to the silver body. All that remains in the bodywork area is applying trade decals and clear coating everything. The chassis is about half done and Iíve begun work on plumbing and detailing the motor.
Thanx for lookiní,
Male Number of posts : 425
Re: A/Fuel Front Engine Dragster - Enderle Injected BBC Power - 13-06 Update
Post by allan on Mon 01 Jun 2015, 11:52 am
Male Number of posts : 9583
Post by baZOOKa on Mon 01 Jun 2015, 4:01 pm
Sittin next ta Allan ! † popcorn
Post by 70cudatj on Mon 01 Jun 2015, 9:04 pm
Post by Bernard Kron on Sun 14 Jun 2015, 3:00 pm
All the major assemblies are now done. As I write this Iím in the middle of final assembly. Below are some pictures showing the Replicas & Miniatures Co. of Maryland photo-etch wire wheels I used with a breakdown of the various parts in the system and final result. Beautifully detailed with some incredibly finely detailed parts (check out the hubsÖ), they are a tremendous improvement over the kit wheels.
The motor is finished and fitted to the chassis. Not shown in the pictures are the injector stacks and the zoomy headers. Much of the rest of the build is straight out of the kit. The one change I have made is to run the steering tie rod outside the body, again not shown because itís a one-shot deal during final assembly and doesnít lend itself to a mockup.
Iím shooting for completion this weekendÖ Hopefully the Gloo Gawdz will cooperate.
Thanx for lookiní,
Post by mgy125 on Sun 14 Jun 2015, 6:07 pm
Very nice!
