AMT '40 Ford Tudor Box Art Build - Update 10-11
Post by Bernard Kron on Sun 01 Nov 2015, 11:23 pm
This will be my entry for the 1940 Ford 75th Anniversary Group Assembly Scheme. It’s my first ever box art build and will be the yellow custom from the side of the original release Trophy Series of the AMT ’40 Ford Tudor Sedan. I only have later releases and will have to substitute a few parts and have to do something about the scallop decals. Bt at least it’s otherwise relatively  simple and gives me a chance to get it built in time for the deadline (which I have just learned has been informally, and graciously, extended – hurray!!!).
Here’s the box top and the side panel:
And here’s a close up of the yellow custom version with the cool early style Dean Jeffries scallops. You’ll notice I circled the rear fender area. There are 2 scallops back there. If you compare the original decal sheet to the illustration and add up the number of decals, taking into account the rear deck decal on the sheet which wouldn’t be visible in a front ¾ view, there should be 11 of them. But on the sheet there are only 9! And to compound the problem the decals for the rear fender on the sheet don’t actually look like the ones in the illustration.
Here’s the yellow custom:
And here’s the original decal sheet as shown on the wonderful and invaluable Drastic Plastics Model Car Club instructions pages (see http://public.fotki.com/drasticplasticsmcc/mkiba-build-under-c/amt-instructions/automotive-cars--pi/ford/1931-1940/amt-19391940-ford-s/ ). I circled the offending decal.
The rear fender decal is really quite large Here’s a picture from the inside of the instruction sheet showing a slightly different variation on the box art car – it’s a ’39, it’s dark colored, and, frankly, it sits way lower (no rake, too) than the kit offers. But, most importantly, the fender skirt scallop (in this version there’s only one) doesn’t look like the one on the sheet (it’s skinnier), and it’s much smaller.
The back of the decal sheet offers a clue as to what they intended, although I think it’s still too large, but at least it looks like the one on the sheet.
But, Box Art is Box Art, so yellow it will be, and with the double scallops on the rear fenders! So… since the original decals in the DPMCC scan were pretty funky anyway, I decided to reconstruct them using Photoshop. And, since I was doing that, I decided to create my own version of the two scallops on, and behind, the rear fender skirts. I think I did a pretty fair approximation. The challenge now will be to double check my work by making some proof decals and applying them to the actual body, and then find a custom decal house that can make some for me since they have a white border which I can’t print! Oh, and get it all done in time for the December build deadline.
Here’s my version of the kit scallops, including the fictitious double scallops on the rear fender:
Other than that I’m thinking of a pearlescent yellow paint job, in keeping with era (the box art is somewhat silent on the matter…). I have a set of the correct AMT style Moon discs but lack the original capped exhaust dumps that came in this release. I’ll probably use the somewhat larger set from the AMT ’49 Ford kit. I may also take some liberties with the very plain interior in the drawing, and perhaps finish the running boards  and engine compartment in white, although the white ‘boards may prove to be too great a departure from the box art to survive.
The car will be lowered beyond the raked stance that the kit yields (the box art doesn’t appear to have any rake). And I’ll attempt hand painted whitewalls which would have been the practice at the time. Other than that it lwill be pretty much straight out of the box but with more modern attention to detail.
Male Number of posts : 425
Re: AMT '40 Ford Tudor Box Art Build - Update 10-11
Post by mgy125 on Mon 02 Nov 2015, 7:30 am
popcorn ...one of my favourite models and one of my first as a child a long time ago.
Post by allan on Mon 02 Nov 2015, 8:45 am
Post by Bernard Kron on Tue 03 Nov 2015, 1:35 pm
Thanks to the generosity of a member of the Model Cars Magazine Forum I was able to get a clean 600 dpi scan of an original decal sheet. The first image I had made it very hard to determine the white areas. In fact the sheet has white pinstripe and lettering decals which were completely invisible. By fiddling with the brightness and contrast on the high quality scan I got I was able to clearly see the white areas. Using those I re-drew the decal art and adjusted my rear fender and skirt decals to more closely match the details of the AMT original art. Here's a fake-o rendering of the original sheet with all 11 decals required to make the yellow custom on the box.
Post by ozmodeler on Wed 04 Nov 2015, 8:18 pm
good choice on the box art version. I'm looking forward to seeing the decals.
Post by Bernard Kron on Thu 05 Nov 2015, 2:17 pm
I think I’ve finalized the artwork. In order to test for fit and any detail changes I printed a set on plain paper with green substituted for the white borders and attached them to the bodywork. I was surprised on how good the fit turned out to be,  especially for the skirt and rear fender scallops which are not on the original decal sheet but are on the box art drawing. I had though I might print some actual decals but it appears it will not be necessary. So, now to create proper vector-based master art and then off to the decal printers.
Here are a couple of (very rough) mockups showing the overall look. The scallop bits are held in place with cellophane tape.
Post by mgy125 on Thu 05 Nov 2015, 2:29 pm
Nice...captures the box art perfectly.
Post by scummy on Thu 05 Nov 2015, 4:42 pm
Coming along nicely , you dont see many of these built .
REV ! Ya back !!!!
Post by mgy125 on Thu 05 Nov 2015, 6:32 pm
Yuppers...starting to get settled in to Victoria finally. Even been poking around the models again.
Post by Bernard Kron on Fri 06 Nov 2015, 1:54 pm
Thanks!
TRaK forum member John Goschke, a fine modeler who knows a thing or two about '40 Fords and scallop paint jobs, let me know that he thought the rear deck decal was actually supposed to be positioned inverted from the way that I have positioned, on the lower splash pan pointing upward. A search of web images drew a blank and the instruction sheet doesn't show decal placement other than the box art and the little illustration shown above. So I checked the image sizing against the 1:1 scan and it was spot on. Next was to flip the test "decal" and place it in the lower position. The dimensions conform precisely to the width of the bottom pan and the contour of the trunk lid edges as they join up to the fenders. So, on the evidence it appears to be as John said. Below is a comparison of the two. Having set my "mind's eye" to the upper position it looked a little odd to me, but it's visually logical in that  the scallops all work together to draw the eye toward the lower edges of the bodywork.
Post by Bernard Kron on Sat 07 Nov 2015, 12:21 am
Several people have inquired about getting copies of the scallop decals I'm working on. You should know that, if you want excellent copies of the original, Greg Holland (vsrn on TRaK) at Greg's Decal Graphics has the complete original decal sheet including the racing numbers, the "Rapid Rickshaw" logo, and the pinstriping. Greg is very well known for the high quality of his work. Here's a link to Greg's site: http://vsrnonline.com/gregsdecalgraphics/index.htm The white logos, shoe polish numbers, and pinstriping are highlighted in black in the sample image, but like the white areas around the scallops, which unfortunately don't show up on the image Greg sent me, they  are printed in white in the decal set he makes. Greg uses the system Chuck Cady uses where the white areas are printed as a separate decal layer. Greg is very well known for the high quality of his work. Here's a picture Greg sent me of the sheet:
Post by Bernard Kron on Wed 11 Nov 2015, 10:18 am
This is a small update. I got the stance dialed in. The dropped front axle from the kit had some leaves removed from the spring and the front cross member shaved a bit. I also lowered the rear suspension to the maximum by hogging out the rear cross member and sinking the rear spring down as far as it would go after trimming the rear suspension stops. This will consistitute a slight departure from the box art which shows the front end slightly higher than I have it. However, out of the box the rear suspension is stock height and, with the kit dropped axle the car has a classic late 50'-early 60's California nose-down rake. This stance is lower overall and just about pan flat, more in keeping with a car with skirts.
The body I've been using is getting a bit worse for wear. I've used it as a mockup on a couple of builds already and it's picked up some nicks and scratches. I have a complete kit with the bags unopened and I think I'll work from that one from now on, using the chassis I have set up. I also got some paint, Tamiya TS-16 Yellow and Tamiya TS-65 Pearl Clear. I'll do a test shot to make sure the effect is what I'm going after. Once the deals are printed and applied the whole deal will get transparent clear gloss coats.
Thanx for lookin',
Post by Bernard Kron on Tue 15 Dec 2015, 1:54 pm
I hit a major log jam on this project as I learned all about having custom decals made, in particular the complex ins and outs of ALPS printers and their relationship with bit map images. It’s far too arcane for this w.i.p. but the bottom line is that I had to make a command decision regarding whether I would stick with white edges on my decals or seek another solution, especially if I was to celebrate the 75th anniversary of the ’40 Ford and not the 76th! So, in order to make the December deadline for the community build I decided to change the decal art.
For those who have followed this build so far you might remember that I had done some sample art that had green edges so I could print check decals on my home inkjet printer. As it happened I got a lot of complements on the look they created so I decided I would use green edges on my final decals.
Progress has been made on other fronts in the meantime. The body was prepped for paint. This involved the usual filling and sanding to eliminate seems and dips, and an important modification that’s specific to the AMT ’40 Ford series. A big thank you to John Goschke for this one! The trim molding on the AMT ’40 Fords (all 3 of them - .coupe, sedan and sedan delivery) are very “weak”. They’re shallow and are difficult to foil properly, particularly on the hood. I noticed on a w.i.p. that John posted he was adding styrene strip to the moldings. I asked John what he was using and he told me .030” x .010” strip. So that’s what I used. While I was at it I added the additional trim molding above the grille that’s  missing from the AMT ‘40s. Hopefully this will all pay off come BMF time.
The basic body was the painted Tamiya TS-16 Yellow with three coats of Tamiya TS-65 Pearl Clear. The pear clear was a disappointment since, much like Tamiya’s Pearl White, it lacks iridescence and doesn’t show up well. Oddly, as you’ll see in the pictures below, digital photography seems to highlight the iridescence more than what you see in real life.
The motor is stock from the kit, of course, and is about done except for wiring and plumbing. One cool feature, thanks to Johnny Stäveborn in Sweden, will be a set of original exhaust dumps from the first issue of the kit, just like on the box art.
As long as I was departing from the strict box art by doing the  green edges I decided to proceed with the white trim theme. The undercarriage is entirely done in white and yellow and the engine compartment is finished in white, too. On the box art the engine compartment is yellow. The interior will be box stock finished in  white with gold trim.
Here’s some pictures of the body. It will get several coats of clear. Perhaps that will enhance the pearlescence, although I don’t have high hopes on that…
Below are some detail shots of the final decal art, the engine compartment and the undercarriage. I think I have a shot at making the deadline – fingers crossed! At least the green trim goes with the holiday season. I think the overall look will stay faithful to the box art.
Thanx for lookin’
Post by allan on Tue 15 Dec 2015, 3:16 pm
WOW that's bright. need my sunglass Laughing
Post by mgy125 on Tue 15 Dec 2015, 3:27 pm
Nice.
Post by Bernard Kron on Thu 17 Dec 2015, 1:23 pm
Thanx guys!
Here’s a brief update. I’m making good progress. The body is cleared with Duplicolor Clear. A couple of days to cure and then I’ll rub it out. ,In the meantime the motor is wired and plumbed and installed and the interior is finished. Are couple of pictures of the interior are mbelow. The gold stripes are TT29 Gold Trim Tape with the main interior surfaces done in Duplicolor Oxford White with Tamiya Gold Acrylix paint and highlights in chrome silver gel pen.
Thanx for Lookin’,
Post by mgy125 on Thu 17 Dec 2015, 1:47 pm
I am loving this build. Nice work.
Post by Bernard Kron on Mon 21 Dec 2015, 3:12 pm
Thanx!
After an intense last few days of clear coating, polishing, foiling, detailing and assembling, this project is done. Modeling in the modern style with all the high quality tools, materials and techniques we have at our disposal really changes the basic character of the resulting model, even when we’re trying to replicate box art from the beginning of the 1960’s like this. Our paint is better, we can detail out things like chrome trim and engine plumbing in ways that were, for most modelers, difficult or impossible 50 years ago. Combine that with the fact that much box art is an idealized version of the real car or the model (which is it, anyway….???) and box art builds can only be an approximation of the artist’s conception.
I printed out a large AMT logo (some 7 inches tall) to provide a background in an attempt to replicate the box art composition in photographic form using my model. But the drawing is hopelessly distorted in scale and perspective so the best I could hope for was to try and capture a bit of the spirit of the original. I took some liberties in my final build, not only using green edges on the scallops so I could print my own decals, but finishing the engine compartment in white, and using white running boards. But the real difference is the crisp realism of a modern model, which contrasts strongly with the fuzzy idealism of the 1960s.
I only had time today to shoot some images to create my version of the box art. I’ll photograph a formal set of “beauty shots” and post them tomorrow. In the meantime here’s the result:
Post by 70cudatj on Mon 21 Dec 2015, 10:06 pm
Nice bigthumbsup bigthumbsup bigthumbsup
