Chemical tankers
Chemical tankers
Post by clea on Wed 23 Mar 2016, 3:44 pm
Just meandering a bit, over the years, you think...i want that, I'll buy that. Then you start thinking.....what do I need to make it?
You sit and think about things logically, do a bit of reference...then get off your arse, AND GIVE IT A GO. It's not rocket science.
These two started out as 1 metre of pvc pipe from Reece hardware,...$3.00 and a few bits of plastic...and a bit of common sense
PVC pipe, 2mm ends, carved the suspension, 2mm plastic
sheet guards, bit of channel.
Bit more plastic for the hose trays
Make a dolly for the 2nd one.....Just plastic sections !
And after a LOT OF SATISFACTION....voila ! you've done it, something you can tell others..
I BUILT THAT !
It amazes me that people buy a kit, and spend the same amount of money on aftermarket stuff,....and say "I built that"
Maybe a bit harsh..?
Re: Chemical tankers
Post by mouse on Wed 23 Mar 2016, 6:07 pm
mouse
Male Number of posts : 151
Post by dv8v8 on Wed 23 Mar 2016, 6:13 pm
Post by Antwon on Wed 23 Mar 2016, 9:23 pm
Your work is something to be proud of Clea, proper scratchbuilding at it's best.
It's only plastic until you add your imagination!
I'm genuinely enjoying your work..................makes me want to start one of mine.Very Happy
Post by 70cudatj on Thu 24 Mar 2016, 12:00 am
They are impressive bloke! Some Real Estate needed to show them off eh? twothumbsup
Post by Cols56 on Wed 06 Apr 2016, 8:11 pm
Love the tankers is that 75 MM pvc looks the goods !!!
