clear coat
clear coat
Post by Johno on Fri 17 Jun 2016, 11:03 am
Hey boys, need a bit of advice re clear coat
I just clear coated a body im building and the clear has gone cloudy, i use duplicolour rattle cans for all my work and hasnt happened before, i heated the can before spraying and gave it a good shake, im on the nsw sth coast and the temp in the shed was about 13 degress, could that be the problem, being to cold, and if so can i rub the clear coat out or wats a good fix ?
Cheers johno
Johno
Male Number of posts : 256
Re: clear coat
Post by DeeCee on Sat 18 Jun 2016, 4:31 pm
Lightly block it, and re shoot a bit more clear, i have had this happen when it was cold and i put it on too thick.
I now have one of those big 100watt spot lamps in my booth, if it looks a bit cloudy, i hold the
model under the light, and it clears up instantly..
Re: clear coat
Post by Morrie on Sat 18 Jun 2016, 9:53 pm
Acrylic Clear and even solid colour dose that when its cold and or you lay it on to thick and wet, if your really lucky it will clear up, its best to wait until its warm and sunny, I spray it out side in the sun, you shouldn't have to worry to much about anything getting in the paint as it dries pretty fast, doing it in the sun works well and you can lay it on a little thicker so it slicks off nice and smooth. I don't think warming the can will do anything, that mainly works with Enamels.
Male Number of posts : 355
Re: clear coat
Post by Johno on Sun 19 Jun 2016, 10:22 am
DeeCee wrote:Lightly block it, and re shoot a bit more clear, i have had this happen when it was cold and i put it on too thick.
Thanks DeeCee, i will try blocking it out,  it was my own fault as id had this body preped for a while and got to anxious to get it onto the shelf, a real doh ! moment for me,  havent had much time at the bench lately so was getting  overly excited to finish
Thanks again for the advice bro, cheers Wayne
Johno
Re: clear coat
Post by Johno on Sun 19 Jun 2016, 10:28 am
Morrie wrote:Acrylic Clear and even solid colour dose that when its cold and or you lay it on to thick and wet, if your really lucky it will clear up, its best to wait until its warm and sunny, I spray it out side in the sun, you shouldn't  have to worry to much about anything getting in the paint as it dries pretty fast, doing it in the sun works well and you can lay it on a little thicker so it slicks off nice and smooth. I don't think warming the can will do anything, that mainly works with Enamels.
Thanks Morrie,  as i said i got overly excited to finish,  i always warm my rattle cans before use, i think i read on here somewhere that it makes the paint flow smoother and more even, anyway i usually have no trouble with them but got to pushy and paid the price, lol
thanks for your advice bro, cheers Wayne
Johno
Re: clear coat
Post by Antwon on Sun 19 Jun 2016, 5:30 pm
Just to wade in here a little guys. I work as a rep selling automotive finishes to the crash trade and I can tell you that most paint companies do recommend warming your paint (and clear) in cold weather. Some crash shops in colder areas use a Bain Marie (Food Warmer) to heat up their clears before spraying. (Sorry Morrie). Also, like Dale does, warm your spray area if possible and the piece being sprayed. I have warmed all paints (Enamel & Acrylic) for years during winter and it stops the clouding issue everytime, plus helps the topcoats flow out to achieve better gloss.
Good luck with future painting.
Re: clear coat
Post by Johno on Sun 19 Jun 2016, 6:13 pm
Thanks Antwon, good to know im on the right track, cheers
Johno
Re: clear coat
Post by Tubman on Sun 19 Jun 2016, 8:23 pm
I use a warmed spray box as well. Used to spray auto acrylic in the middle of winter in Canberra, never a problem. I just have a down light in mine and can have the model as close as a couple of inches. It's warm but not hot so won't meld your models.
Re: clear coat
