the generals wip
the generals wip
Post by doorslammerfan on Thu 01 Jun 2017, 7:52 pm
1st I cut the body to add a wedge
wedge  glued in and 1st bog layer sanded
widened the hips to clear the huge Hoosiers and sliced the rear pillars and cut 4 mm out of the front pillars
next to its former identical twin
reshaped and added lips to the guards
bit of a mockup
Re: the generals wip
Post by doorslammerfan on Thu 01 Jun 2017, 7:57 pm
start of seat and driveshaft tunnel
basic cage chassis done, you can see from these shots that all pedals can move
firewall started
Post by doorslammerfan on Thu 01 Jun 2017, 8:01 pm
brakelines and multi piece master cylinder in place
wheelie bars started and dirt modeller pe brackets
front struts
start of magneto
Post by doorslammerfan on Thu 01 Jun 2017, 8:05 pm
start of the air shifter
air and fire bottles
lots of stuff going on including colour, saftey blanket on trans, seat in place saftey belts bolted in
Post by doorslammerfan on Thu 01 Jun 2017, 8:10 pm
start of the fuel pump
wiring done, pump in, mallory ignition box done, fuel cells in and purge lines run
diff in just needing to paint wheel backs at this stage
cut off front of hat, drilled it out, drilled out the hat and made butterflies. Closed
Post by doorslammerfan on Thu 01 Jun 2017, 8:14 pm
open
on wheels mostly done
steering wheel and blower pullies
battery clamps
done
Post by Deadly on Fri 02 Jun 2017, 6:51 am
Mate..............................words simply cannot say what you have created here. How much time went into just making the chassis, let alone all the wiring & other fiddly little bits & pieces ??? You made the pedals, & butterflies operate, & you made your own battery clamps  bowdown  This is not simply a model car, it is a piece of art.
All I can say is :-
wowwee wowwee wowwee wowwee wowwee wowwee wowwee wowwee wowwee wowwee  wowwee  wowwee
drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly drooly  drooly  drooly  drooly  drooly  drooly drooly  drooly
yourock yourock yourock yourock yourock yourock yourock yourock yourock yourock yourock yourock yourock
Male Number of posts : 541
Post by doorslammerfan on Fri 02 Jun 2017, 11:27 am
cheers mate, appreciate that, glad you like it
Post by DeeCee on Fri 02 Jun 2017, 10:45 pm
HOLYSHIT !!!!!!
The detailing and craftsmanship in this build is off the charts mate, that is just INCREDIBLE !!!!
wow
Post by micsmav on Sat 03 Jun 2017, 8:34 am
wowwee wowwee
I would have to wonder Brett , what the out come would have been with 2 hands Thats sensational
Post by Carps on Sat 03 Jun 2017, 10:24 pm
greatwork iagree Awesome work, you really outdid yourself on this one.
Post by doorslammerfan on Sat 03 Jun 2017, 10:32 pm
thank you all very much Smile
