Kenworth Aerodyne
Re: Kenworth Aerodyne
Post by Deaf as on Mon 16 Apr 2018, 8:16 pm
Haven't been able to get much bench time recently but have been moving along slowly
A combination of spares and scratch built to make a lazy axle. As it's under the body it should be fine. Made up a subframe for the tow body to sit on to lift it a touch higher than the 1 that came with the body.
The pink section to the left of the tank bracket is a 30mm piece I had to add so that I could fit the tanks on and get the aircleaners and exhausts between the cab and body.
I replaced the kit front axle with 2 white metal ones from KFS mainly for a uniform look. Scratch built some steering linkages and put the battery boxes between the front axles, mainly cause there was no where else to put them. The aircleaner barrels will be fixed into place once I make up some new cab mounts - the old ones are busted.
So this is it all sat together to get an idea of how it was shaping up.
I'm using some of the Auslowe upgrade sets on this build. The headlight and quarter panels are 1. This gives individual headlight buckets. Also using the cab mounts and aircleaner sets. It's taking a bit of sorting out with the stretched cab  but would be pretty easy on a standard cab I'd think.
Male Number of posts : 1204
Post by allan on Tue 17 Apr 2018, 8:02 am
Looking good, will get light bar in the mail.
Male Number of posts : 9673
Post by mutley on Tue 17 Apr 2018, 6:01 pm
reckon you'll have it fuelled up for Wagga
Male Number of posts : 338
Post by Deaf as on Sat 21 Apr 2018, 9:44 am
The light bar turned up in yesterday's mail Al, many thanks once again for your generosity. Hopefully it'll be done for Wagga but........
Post by allan on Sat 21 Apr 2018, 11:10 am
Glad to help, hope it works out for you.
Post by Deaf as on Sun 29 Apr 2018, 9:17 pm
A few more bits and pieces have gone on.
The Auslowe stuff went together pretty well, just need to remember to increase the length of the pipes on the back of the cab if you raise the cab after putting the flares on. Nearly time to reprime it and see how it looks.
Post by allan on Mon 30 Apr 2018, 7:54 pm
Post by Deaf as on Mon 07 May 2018, 6:06 pm
Chassis has been painted and other parts primed. Chrome paint on rims wasn't what I'd hoped for so will have to redo them - plenty to redo Crying or Very sad Have been getting some paint & polishing tips from Dee Cee so the cab has gone back onto the work bench for some more prep work. I'll add some pics soon.
Post by allan on Mon 07 May 2018, 8:15 pm
Post by Deaf as on Wed 30 May 2018, 9:14 pm
Quick final mock up before cab painting.
Post by Deaf as on Thu 31 May 2018, 10:25 am
Base colour on .
Masked out. Based on Kenworth's factory scheme - Potomac.I changed the front a little and will only use 2 colours where the diagrams for it show 3.
Chassis is pretty much done except for mudflaps and the like. Still working on the wrecker body, changing taillights as I didn't get the kit ones. Pinstriping on the cab next and then extend the interior tub to fit.
Post by allan on Thu 31 May 2018, 2:14 pm
That's coming a long nice.
Post by Deaf as on Sun 03 Jun 2018, 7:31 pm
Thanks Al. Been working on the tow body and towing gear.
The kit taillights didn't come with the kit so I decided to come up with something else.
I cut out the recesses, blanked them off and made the new housings. I also sanded the chequer plate detail off the angled edges of the body for a neater look.
Had to change the bracing underneath to get it to sit at the height I wanted.
Started putting the pinstripes on, waiting for the door decals to turn up.
Post by allan on Mon 04 Jun 2018, 2:48 pm
Cab looks good with the pin stripping on it.
Post by Deaf as on Sun 08 Jul 2018, 8:29 pm
Thanks Al. Got a bit more done.
Bit of silvering on the decal for some reason? Reaction to the decal set maybe??
Sorry about the size of the first pics, teach me not to check!
Post by allan on Sun 08 Jul 2018, 9:51 pm
Looking good A+
Post by Deaf as on Sun 29 Jul 2018, 9:07 am
Thanks Al, need to post some more pics.
Post by allan on Sun 29 Jul 2018, 1:10 pm
It must be almost done now.
Post by Deaf as on Mon 06 Aug 2018, 8:17 am
Finding bench time is the killer Al. Still have to modify the interior to fit the big cab so not doing too much detailing until I have that sorted.
Post by allan on Tue 07 Aug 2018, 8:03 am
